96 Upgrade
oh_SHO
Ohio
Ok,
I DID DO A SEARCH! But my question isn't quite clear... So I have a 95 MTX; what excatly do I need for the 96 upgrade? I think its just the calipers and rotors, right? I am going into some junkyards and I need to know excatly what I need. Thanks guys.
SolidState
No Mo SHO
Toronto, Ontario, Canada
you need the following for your 95:
1996 Taurus SHO Rotors
1996 Taurus SHO Brake Pads
1996 Taurus SHO Caliper brackets.
and all the other standard replacement parts in a brake job...
shoinoff95
Wichita, KS
Grifter:
So you dont need 17" Rims, right? Just double checking.
Nope. It fits behind the slicers without any rubbing or clearance issues. I have this upgrade and I absolutely love it; the car stops soo much better now, with less force applied to the brake pedal. thumb
SonicRiot
Handbanana!
CT
You need knuckles for the 96 upgrade on genI? Can I rip them off of a junker 96?
SonicRiot
Handbanana!
CT
Can you reccomend a place to get them? I'll do a search now, but just asking...
oh_SHO
Ohio
Thanks for the replies. So for a 95, I need the rotors, calipers and caliper brakets off a 96 and up taurus. Didn't someone say that the parts are the same for mid-90s LSCs? Or was that just the knuckles?
K-Dawg
Treasure Coast, FL
Its been posted at least once in this thread and many times in the past. All you need for a 96 upgrade on a 94/95 Taurus is 96+ SHO rotors, 96+ SHO caliper brackets, and 96+ SHO pads. The calipers are the same. If it were me, I would get loaded rebuilt calipers for the same price that you could get just the brackets new. Toss the pads if you want better ones.
oh_SHO
Ohio
Ok ok I see it. I just had it set in my mind that the calipers were different. Alrighty then I smell upgraded brakes next month! Since I am low on funds I will probably just keep the calipers I have and replace the upgrade parts and new rubber lines. thumb
Now what is this rear bias valve mod I hear about? Wait I will search for it before someone bites my head off. :D
SonicRiot
Handbanana!
CT
K-Dawg:
But you need everything, including the knuckles and calipers on genI's, right?
91taurisho
my house, CO
SonicRiot:
K-Dawg:
Yes everything listed above in the thread plus the 94/95 knuckles and calipers will do a pre-94 96 upgrade
