96 Brake upgrade tips
ThrillSHO
Wake Forest, NC, USA
I have gotten several emails with questions about this upgrade so I thought I'd post my tips. Feel free to add your own.
I have done it several times and have a shop complete with lift, air tools, gear pullers, ect. I have gotten the time down to about 3hrs. Here are some tips:
1. Jack the front of the car and place on Jack stands with both wheels hanging. This relieves the torsion on the front sway bar and makes the job easier. Don't try to do one side with the other setting on the ground.
2. Order of disassembly of knuckle: caliper, rotor, tie rod end, lower ball joint, CV shaft, strut tube, ABS sensor. Reverse for assembly.
3. When you unbolt the caliper, wire it up to the coil spring with the brake hose still attached. Don’t disconnect the hose until the new knuckles, ect are installed. Then quickly swap the hose from the old caliper to the new one. This will minimize the fluid loss and reduce the air entering the system.
4. Be careful removing the lower ball joint so you don’t tear the boot. A long pry bar hooked under the frame, pressing down on the control arm works well. You’ll also have to jack up the knuckle a bit to get it out.
5. You’ll need a special 30mm hub socket available at NAPA. You’ll also need a gear puller to pull the hub off the CV shaft.
6. I recommend installing new wheel bearings also. I have a 20ton press, so I did it myself, but a machine shop will do it for about $20 a side.
7. Be very careful with the ABS sensor! It is quite fragile. The housing is plastic and the sensor that points at the ABS ring is thin aluminum. After removing the retaining bolt, GENTLY twist the housing with pliers. If the aluminum sensor doesn’t turn with it, stop. You will have to press it out. About half that I have done had to be pressed. I used a small gear puller and a flat piece of steel between the sensor and the center bolt of the puller.
8. Be sure to clean all the holes in the new knuckles for the strut tube, ABS sensor, ball joint and tie rod end with sand paper (I used various size cylinder hones). It will make reassembly much easier.
9. You’ll need to bleed the brakes and get a front-end alignment when you’re done. The camber won’t be affected but the toe will be slightly off.
Good Luck
jcostantino
Coral Springs, FL
That is for Gen 1 brakes because you have to update them to Gen 2 THEN to Gen 3.
If I'm not mistaken, the Gen 2 Gen 3 update is basically pull the calipers off, pull the brake rotors off, put the larger rotors on, put the new adaptor on and put the calipers back on.
There are other things you could buy like slider pins, etc.. but that's covered in the Howto on shotimes.com and as far as I know, not completely necessary unless you would need them anyways to replace rusted ones.
Jeff
FordLover
Houston, Tx
jcostantino:
Jeff
My gen 2 would require the above, that's the reason my car doesn't have the 96 upgrade yet.
-Martin
NorthernSHO
Ontario, Canada
The 94 and 95 SHO's only require mounting brackets and rotors from a 96-99 SHO to do the upgrade but any SHO from 89-93 will require all of the steps that were mentioned above. Glad I have a 94...my car is actually at the garage right now getting new suspension and the 96 brake upgrade done on it as I type this!! I can't wait until my drive home tonight...except that it's snowing out! Doh!
Xs SHO 1
Unknown
McHenry, Illinois
besides the ball joints, is there any other bushings or other misc parts that should be replaces while we're in the area? i have 168k on my '93 AXT. anyone who had done the brake upgrade, you'll know what i am talking about. :p
Xs SHO 1
Unknown
McHenry, Illinois
i finally replaced the bearings on the '94 Sable knuckle for my '93 SHO brake upgrade. the '94 Sable caliper was seperate from the knuckle when i got it from the boneyard. it did not come with the 2 bolts/pins that connects the caliper assemby to the knuckle. i take it i will be getting those bolts/pins from the dealer or local parts store? anyone? help? frown
