95 Rear Door Removal - Help
eacyde
Pinkley Taurus
Calgary, Alberta, Canada
I need to swap out my rear doors and I can not seem to find a connector inside the door or inside the pillar to disconnect the wiring. All I can see is a connector for the window motor.
Is there more connectors in there or do I have to cut the wires?
Thanks
there is definitely a connector there. iirc, it is in the B pillar.
mrecoolgar
SHO NUP
Hershey-PA
The connectors are not in the door, they are in the car.
Inside the B pillar as stated.
The wiring exits the front of the door and goes thru the rubber 'hose' then into the car.
Remove the interior trim and you will find it tucked into the base of the B pillar.
mrecoolgar
SHO NUP
Hershey-PA
There are connections inside the door at each component.
However, it is easier if removing a door to disconnect the group of connectors at the B pillar.
eacyde
Pinkley Taurus
There is no connector in the B pillar. There is a single connection inside the door behind the power window motor. At least in all the 2nd gens that I have taken apart. Maybe 1st gens are different.
The way I remember the Gen2's that I have had apart is that the connector is at the bottom of the B pillar as Kevin stated, but its been long enough that I cannot swear to it. (For some reason I can remember stuff from 30 years ago better than stuff from 5 years ago - maybe my brain is full...)
313tiger
