95 Mtx ring gear bolts and nuts needed where to get them?
shomethe$$$
Washington D.C.
Ring gear bolts and nuts, should work for an OE diff, ask shonut, I can test fit them if in a stock diff if you need it
http://www.shonutperformance.com/
click MTX at the top and look for:
Differential ring gear M12-1.75x35 grade 10.9 Bolts/Locking Nuts (10 of each, single use due to locking nut) (N802-393-S100 M12-1.75x32 grade 9.8 bolts and N802-389-S M12-1.75 grade 10 nuts are obsolete)
zak
east of Hartford
When I did my Quiafe, I took it down to Fastenall or a similar fasterner supplier. The holes in the Quaife are ever so slightly smaller than the ones in the ring gear. I sorted through a big box of half inch (x ? length) Grade 8 bolts to find ones that just fit.
zak
east of Hartford
Those are metric, be sure to check fit into the Quaife itself. I know the OEM Ford ones are metric as well, but may have been a custom part.
