95 3.2 water pump
kevinspann
Don't take my advice.
Richmond VA
I don't think that was the correct image. There is only one thermostat, on the drivers side of the engine.
sho'noff
shoverdrive
the land of the setting s
that's ok I think it wasn't the right image also. it has the new gasket on there and only the water pump gasket. it was too much to get the o-rings and such on there plus the backing plate for the water pump needs another gasket to be able to get to anything else.
time for some new antifreeze as I flushed the radiator via garden hose in the radiator cap with the water pump off and the drain open.
SHOtimer
#2910
Santa Clarita, Ca
Be careful only replacing the front. A lot of time that small O-ring for the block can be disturbed and leak afterwards.
It's only a $8.00 kit from autozone.
Doug
Irish Pride
Irish Inside
MusicCityUSA
You will regret skipping the water inlet gasket and the cross over tube o-rings. You are going thru all the effort to get to the water pump, do it the right way.
