94 bigsho
hi, i have a 94 sho with factory remote keyless entry and the door keypad. Anyways the car sat for a few months with the battery dead and the keyless entry and the first 3 buttons on the doorpad will not work. I was reading on how to reprogram the keyless entry and I went out and try to do what it said which was to turn the car on run or acc mode and jump the 2 pins on a connector located on drivers rear quarterpanel. It also has 2 wires and its a grey connector. You should hear the doors lock and unlock and they didnt. I'm not sure if its the right one but the only one i can find. Also I have a black connector in my trunk that i see is disconnected which also has 2 wires in it. It was just sitting in my trunk disconnected and i'm not sure whats its for and where it goes because i was searching for 30 minutes trying to find the mating wire harness for it and no luck. I dont think ford would leave a hanging harness back there with nothing for it to plug into. Oh yeah, remote keyless worked fine before i stored my car over the winter. The first 3 buttons on the keypad never worked to my knowledge but the last 2 do they lock the doors fine. Any help would be appreciated, i'm new here and pretty new to the sho. I love my car and I have been reading quite a bit around here and it sounds like you guys really know what you are talking about. Thanks in advance
