sho2see
sho2see
94 MTX with 13" cobras in front and stock in the rear.
First my passenger rear brake was rubbing & one pad was to metal. So yesterday i did the brakes(new rotors with new pads plus lubed the slide pins) and it rubbed again. Looks like the e-brake is engadging but not disengadging. So I had to leave the e-brake cable disconnected from the PR caliber. Worked out just to get home but the driver rear is doing thte same thing but not close to as bad as the passenger side. Any suggestions?
Also my driver front is making a screeching noise from the brakes to. The front are 13" cobra with the dual piston calibers. And the bottom i guees the circle metal thing(theres 2 i guess that hold the brake pad to the caliber) is missing. I guess fell off while driving. Can this cause the squeek in the front?
Thanks
Dno
Thanks
Dno
Is the brkae piston getting stuck maybe or a wheel bearing?
