93 atx brakes and handling?
sccasho
kenova, wv
just changed the rotors and i still have a wobble when braking. could i need an alignment or is it something else? shrug
projectSHO89
SHOless In St L
It's still a rotor problem. Alignment issues won't cause this.
WHICH rotors did you replace? Font, rear, or all of them?
Do check out your wheel bearings, front and rear.
Steve
Mr Anonymous
Tire Wall
Did you replace just the rotors and not the pads??? Did you make sure to torque the lug nuts properly to 85-105 lb. ft. in the proper star order?
