Shoaz
Studly dood
What model year is your car? IIRC the 24mm front bars were only shipped on cars with 26mm rear bars (GenI, 89-90 or so), so if you took something smaller than a 26mm off the rear, it's likely that you have something smaller than 24mm in the front.
Check your front end links to make sure they're not damaged/disconnected. It won't matter how thick the front bar is if it t'aint hooked up well.
Serious oversteer will be the result of something being seriously wrong or you've got much less effective front bar than you think you do.
