The copper, yellow/purple, and green/purple wires are part of the 6F55 Transmission Range Sensor (TRS) circuit. The bare copper wire is the drain or shield ground—it has no insulation because it’s designed to ground out electromagnetic interference rather than carry voltage. The yellow/purple wire is the TRS signal return, and the green/purple wire is the signal output to the PCM, both carrying low-voltage logic data that tells the PCM the current gear position; when the foil shielding or drain is compromised, EMI and heat can distort or interrupt those signals, causing the exact intermittent transmission loss and fail-safe condition I’ve been fighting.
I marked in red the portion that is the transmission main harness that plugs into the solenoids in the transmission cover. And the white marks where I’m going to cut open a little more. And redo all of this. The copper wire isn’t shielding anything down here
I’m using a ratchet strap to hold my coolant feed lines and coolant hose to radiator out of the way for more access in this photo
