Sayow
Hello everyone,
I am about to let a local shop (recommended by shotimes.com hall of fame list) do a full 60k service + timing belt (100k?). I was quoted approximately $1500 and was told that would include the full 60k including waterpump, timing belt, ATX system flush and check, new plug well seals, and EGR adjustment.
First, is this a good price?
Secondly, what do i need to make sure they do as part of this service?
And last, do some of the experts here have some advice on some additional things I should consider doing or having check while they have it all opened up?
I asked about a transmission cooler and / or a shift kit and was told that they would check it and flush it (since we know it has been changed before) but they recommened NOT adding a shift kit or a cooler until it goes (which they said it would) and then do it all since just adding pieces may actually end its life prematurely). The shop said that the SHO engine is bulletproof and a great engine but that the ATX is garbage.
The shop seemed to really know what they are doing and the mechanic owns 3 of his own and is pretty much exclusively a SHO mechanic for them. He said that for $1500 he will make the engine as good as new and it would be never be a problem again (he said 300k is not uncommon if they are done right).
What say you all?
Thanks
What say you all?
Thanks
