5-100 bolt pattern for sho will fit?
carlsho
Montreal
I just found a set(4) of 16x6, 5-100 bolt pattern aftermarket wheels for my 89sho. I would like to know the offset for the slicer wheels 91+ and the bolt pattern. Will these aftermarket wheels fit on my car?Thanks
RI-SHO
B to the BANNED
Pawt., RI
I think all Taurus models including the SHO have the very non-popular squint 5x108mm bolt pattern and the slicer offset I believe is 45mm.
RStalveyARFF
too many shos
Georgetown, MA
the SAE measurement is 5 x 4.25" if that helps in your search. Volvos, S-types, windstars, taurii, sables, and t-birds/cougars are the most popular users of this pattern.
91 SHO PLUS
COLUMBUS, OHIO, USA
Carl,
The bolt circle for the SHO is 5x108mm, same as 5x4.25". The offset is +42mm. The slicers will work fine, and look nice, but the Gen III SHO chrome wheels are awesome. thumbs_u Also, the Gen III's are 6.5" wide, which works great with 225/55/16 tires, and also no rubbing problems! burn_out
Good Luck,
Jeff
pjtoledo
'ol man in the SHO
toledo,ohio,usa
There is only 2-thousandths of an inch difference between 4.25" and 108mm. Call it what you like, that little bit is smaller than production tolerances!
Perry Toledo,Ohio
