strings1732
RMTE-TRBO-SHO
what pump are you running for the oil scavenging
I've got the filter in the back corner and it shouldn't see too much driving water. Plus, that's what the filter sock is on there for. Water cant get thru it.
any thoughts on placing the filter up in the trunk with some sort of shroud around it to limit a loud sucking noise in the cabin of the car just in case one happens upon a nasty rain storm whilst honda hunting?
you must be mad if you want to quiet the sucking noise a turbo makes! With am much power as a turbo adds you quickly learn to respect that racing in poor weather is a bad ideal.
Worst post ever.
-Sam
Sam is fully aware of the differential situation.Worse post ever, hmm, well lets see. You know that little metal box between the motor and wheels smart guy? It's called a transmission. For one, there is some power loss when torque is passed through it. That power loss is exchanged for heat. Ford, or whoever built the sho mtx screwed up designing the diff. Improper ****, and guarantee to fail pins. If he doesn't have a quaife or at least the diff pins welded, your not getting 400lbs+ of torque to the wheels for very long without the pins flying right out of a ************* mtx tranny. Seeing I have two SHO's, rebuilt my 90, blew a diff with a stock powered motor!, about to make a showagon, I think I know what im talking about. Thank You!
you know that kind of speech people use when they're being facetious? it's called sarcasm...Worse post ever, hmm, well lets see. You know that little metal box between the motor and wheels smart guy? It's called a transmission. For one, there is some power loss when torque is passed through it. That power loss is exchanged for heat. Ford, or whoever built the sho mtx screwed up designing the diff. Improper ****, and guarantee to fail pins. If he doesn't have a quaife or at least the diff pins welded, your not getting 400lbs+ of torque to the wheels for very long without the pins flying right out of a ************* mtx tranny. Seeing I have two SHO's, rebuilt my 90, blew a diff with a stock powered motor!, about to make a showagon, I think I know what im talking about. Thank You!
the closest thing I can think of to equivocate to a diff pin in a RWD setup would the the cross shaft, but they aren't bolted in like a cross shaft.Just curious, what diff pins are you guys talking about? I'm much more familiar with RWD setups.
