3.0L engine/trans, performance parts, gaskets, quaife and more
MWD
Apex, NC
New:
Ford 3.2L Upper Gasket Kit (F3DZ-6079-C): $250
Quaife: $999
Used parts:
-B9B1 EEC $40
-X2J EEC $75
2 MTX-IV $400 each
MTX Input shaft plus output gears (no output shaft) only 40K miles. These came from my *cherry* MTX which was used for an HD gearset. $200
Pictures (will add more as I take them):
http://michaelandjulie.com/SHO/
All prices do not include shipping. UPS shipping from 27502 (or USPS if desired or cheaper).
Michael
MWD
Apex, NC
Crankshaft + Main bearings
Adding crankshaft in very good condition. all journals/bearings in good condition. Key slot is like new. Front/rear sealing surfaces are good. Includes main journal & thrust bearings. $100
Crank
More pics here:
Michael
AREA 91
PA SHO SHOP
Area 91
Interested in the valve shim kit, but I see that i'm 2nd in line.
I WILL takke the new Oil Pump!!!
:woo-hoo:
MWD
Apex, NC
do the 48# injectors need to be tuned before used, or will they work if dropped in?
48# injectors definitely require a retuned computer. The EEC is calculating the time to turn injectors on/off based on a much lower flow rate. It cannot compensate for a large change in injector flow rate.
Michael
MWD
Apex, NC
Last call on the crank before it goes to the recycler. (I will still have the main bearings.)
313tiger
