TWEECER RT w/ X2J ECU $300, CM FX300 HD CLUTCH w/ FLYWHEEL $350, 3.2L ENG $125, 3.0L ENG $100 more:
shomethe$$$
Washington D.C.
Slowly getting out of the SHO game, got some leftover parts, contact text or call: 571-210-0935
Location: Northern Virginia, 20 miles west of Washington DC
Tweecer $300 shipped SOLD
w/0 ECU $250 SOLD
Clutch SOLD
Practically new Clutch Masters heavy duty clutch from ShoNutPerformance less than 1000 miles 93 Ford Taurus SHO V6 3.0 liter with manual 5spd transmission, FX300, ClutchMasters, 3300-3600lb clamp load, 525 ft-lb torque rating, Steel Back Segmented Kevlar disc. Part number 07-078-DDTZ. DD stands for dual diaphragm pressure plate. TZ stands for Sprung segmented Kevlar disc. Comes with flywheel, can discount off $50 w/o flywheel so make an offer. Retails for $600 without the flywheel. Pedal will feel harder. Link if needed:
1993 Ford Taurus SHO 3.2L crankshaft with main bearings and thrust bearings, mint condition, 106k miles. $125 shipped. Block and heads are sold. Valve covers $45 shipped. Timing pulleys, tensioner, and mid cover, $30 shipped.
SOLD 1993 3.2L crankshaft and main bearings, mint
SOLD 3.2L piston set
SOLD 3.2L crank bolt
SOLD 1993 3.0L engine 80k miles SOLD August 2016
SOLD 3.2L crank pulley $35 shipped
MTX Water Pump Pulley and bolts $20 shipped
SOLD Belt Bracket $20 shipped
MTX 3.0L crankshaft pulley $25 shipped
Front: Should fit manual or auto: $35 shipped
P1000783 zpsdncjuubw
Rear Automatic: $35 shipped
P1000782 zpsw9hm7btg
Injectors: SOLD
Accel 48 Injectors $200 shipped.
SOLD 6/27/16 ATX EGR valve and pipe assembly $20 shipped, message for pics, max on this is 20
Shift Fork Lever the arm on the outside of the trans controls clutch bearing, $20 shipped
SOLD OEM Valeo clutch, 5k miles, almost brand new, w/ flywheel $65 shipped
SOLD 3/8" phelonic spacers, $75 shipped
SOLD MTX Alternator
stock 90mm Ford Lightning MAF, SOLD
Speedo Gear $20 shipped
Speedo 001 zpswp6uwyfl
MTX Speedo Sending Unit, spins freely, $30 shipped
P1000951 zpsanwf02kt
MTX shifter internals, from the transmission $25 shipped
Gear shifter 001 zps3eyt2cbm
SOLD CCRM Code "M" 92-up $30 shipped
SOLD OEM differential diff, good for parts $40 shipped
SOLD IMRC
SOLD BAP Sensor
AREA 91
PA SHO SHOP
Area 91
If the fuel injectors fit a standard (non bored) rail I will take them!
PayPal ready.
AREA 91
PA SHO SHOP
Area 91
Did the deal go through with the injectors?
If not, I am ready. Take my money!!!
:wavey:
Devin
3.Slow
Pacific Northwest
I'm interested in the 3.2 shortblock, but I am in the other Washington. If you end up parting it out and become flexible on shipping let me know.
Black Bart
maine
Looking for a 93 atx converter head pipe. Give me a text at 207 538 7391 if you have something. it would be shipped to 04730
thanks
scott
shoray
Hinesville,Ga
Is the mtx internal shift mechanism also known as a shift lever? My rod shifter spins endlessly, is that what will fix it
shomethe$$$
Washington D.C.
These parts selling fast, so many SHO owners that never come on this board, still some demand left. Better get them.
