I've heard you need to use the 3.0's timing belt tensioner on the 3.2 when doing the swap. Why?
Also, why use 3.0 pullies? Wouldn't the 3.2 run just fine on it's one serpentine belt driving it's original components, or is this done because of clearance problems?
Now I know Mark always tells us that the 3.0 and 3.2 are "the same", therefore taking everything off of your 3.0 and putting it on your 3.2 (just like if your 3.0 was bored to a 3.2, it would still have all the same stuff on it). And you would keep everything under the hood the same. But in my case, since I'm going to run my original 3.2 that's already in the car, put in an MTX subframe, and do the MTX conversion, why would I need to change anything that's on my motor now? You have to remember the 3.2's have one belt and different accessory brackets. My question is, would I have to change everything over to a 3.0's configuration just because of clearance issues or is it something else?
I have a lot of people giving me positive thoughts about this conversion and want to make sure everything is covered that needs to be. It will make mine and Drew's job (Mainly Drew's
) go smoother knowing we got everything setup correctly.
Thanks
Thanks
