2nd fuel pump
fuhSHO
Seattle, WA
Well, i was driving to school this morning at 630 (in the pouring rain i might add) and when i get infront of my school, the car shuts off. How convenient, one would think...no. I coast into a parking spot, and its exactly what i thought. Fuel pump is dead...again...for the 2nd time in a month.
My question is...can my car do something that would cause the pump to fail? Or... Did i just get unlucky with 2 pumps? shrug
haydenm315
Reisterstown, MD.
Maybe your gas tank is rusting apart from the inside? I know there was a recall on the gen II's that entailed cleaning the gas tank of rust or something. I'm pretty sure crap such as rust will eat up a pump. Did you change your fuel filter after changing the pump and inspect the old one? It might be kinda dangerous to cut the old one apart, beings it might spark and it still has gas in it. I never did take my old one apart because of this fear.
shobikes
ashevegas nc
the question begs to be asked: what brand fuel pump was installed as replacement? OEM? or something cheaper?
could you have a simple elec. problem from the swap-out, like a bad ground? i would think it pretty damn unlucky to have gotten a bad new pump.
fuhSHO
Seattle, WA
it wasnt a new pump, it was out of my parts car. its very possible this one is just straight up dead too. the gas tank is clean as well.
fuhSHO
Seattle, WA
ahhaha, i did actually! we put it in my dads car. i said it was dirty, he said he wanted it though! rofl
ACV1081
Member #187
IA US
Heck, how about 3 bad pumps in 3 months on my buddys 93 :p One 120K likely original pump, followed by 2 Oreilys lifetime warranty units. I honestly can say I would never buy one of those simply b/c of that expierience. The "trap door" is a must, especially if you have the luck I did. As for installing a used fuel pump, you my friend are a glutton for punishment. nono
fuhSHO
Seattle, WA
under the circumstances, i had to...i have absolutely NO money...my brother put a fuel pump from a junkyard in his T bird and has never looked back. from that experience, i figured why not. i guess im finally gettin a bite in the a$$ for him too... rofl
so, anyways... what kind of pump do i need to get? (most cost effective)
HopefulSHO
Bellevue, NE
I also bought a pump from autoperformanceengineering. (isn't that a mouthful?). Shipped fast and comes with everything you'll need.
fuhSHO
Seattle, WA
im still stock so i dont need anything that has to do with HP gain.
are the auto performance engineering pumps reliable??
someone is offering me a "carter" 174 lph pump...anyone know about those pumps?
DHMag
Free At Last
InCahoots, Texas
the great thing about APE is he lives within an hour from me :) ..saved on shipping, paid in sales tax :rolleyes:
Rockledge
Pluggin' away
Connecticut
fuhSHO:
...someone is offering me a "carter" 174 lph pump...anyone know about those pumps?
It's not used, is it? finger :D
Seriously, that'll do just fine. Just make sure you get a new sock to go with it!!! :cool:
fuhSHO
Seattle, WA
haha yea yea ok i wont put another used pump in!
but i really need to figure out IF there is anything that would make my car fry a fuel pump?? could there be bad wiring or a short circuit? where is the fuel pump relay? what else can i check??
hanshua
Blue Mounds, WI, USA
Couple of things to check... first off, did you replace the fuel filter? If you have an old fuel filter in there, then get it out cause a clogged one is gonna burn through pumps fast... second off.. it is possible that the relay could be sticking causing your pump to run constantly..
If you have an ohm meter and a couple of extra jumper wires try this... pull the relay, it will have a diagram on the side of it that will tell you which contacts should be making contact when.. the normally open ones should read "OFL" when the relay isnt powered up... the normally closed ones should read about 0.1 ohms... now apply 12v power and ground to the relay with your jumper wires... now the normally open ones should read 0.1 ohms, and the normally closed ones should read "OFL" also check for continuity between the no and nc contacts powered up and not.... those should read "ofl".... if you cant get your hands on an ohmmeter... or dont wanna go through the trouble.. just replace the relay... they are cheap.
Also, check for kinked fuel lines and replace if they are... that would cause the same effect as a clogged fuel filter
-Justin
fuhSHO
Seattle, WA
i did a little search and noticed replacing the FPR was a common suggested solution to fuel probelms. could this have to do with my problem as well?
fuhSHO
Seattle, WA
is the fuel filter that thing thats on the end of the fuel pump in the tank, or is there another one somewhere else????
