2017 Ford police interceptor 3.5L ecoboost engine misfire and low power stall when accelerating.
Gstylesho
Canada
Hi i have purchased a police interceptor with the 3.5L ecoboost the engine start crank but with misery like the power is not enough. I check the battery look good. When accelerating the engine stop. Start again and you dont feel the complete power when put in drive it goes but a soon a you press the gas its stop. I check the code i have several one like 2 misfire in cylinder 2 and 5. Also i have a code i dont really understand its P068A
ECM/PCM power realy deenergize performance to early. I have to say this car has no hood no bumper and no headlights looking to install all those parts but need to make sure engine is ok first. THANKS IN ADVANCE FOR ANY HELP.
probably time to do plugs. i would clear codes, see what returns.
did you check the battery with a digital tester like the solar ba9? you have to check voltage AND cold cranking amps in these computer driven vehicles.
Gasoline Engines PCED
P068A - ECM/PCM Power Relay De-Energized - Too Early
Description:
This DTC sets when the non volatile random access memory (NVRAM) write did not complete successfully after the ignition key was turned OFF, prior to PCM shutdown. This DTC also sets when the PCM power relay is de-energized too early.​
Possible Causes:
  • PCMRC circuit open
  • PCM power relay
  • Low battery voltage
Brumfield780
