timmay316
I just picked up a 1994 ATX. Finished all the 60k work (148k with no 60k work ever done... waaaay to much oil in the plug wells), replaced rod bearings, replaced the exhaust and a few other things. It's running better than when I bought it, but there are a few quirks. When I first got the car, it got 33 mpg or so on a regular basis, the fuel mileage is now down to about 20. When driving (regardless of whether the car is hot or cold, from a stop or rolling down the highway), every once and awhile when I try to accelerate, the car will just stutter. If I let off the pedal and push it again the car catches itself and drives like normal. The stutter isnt like a slipping transmission (or VSS issue I have read about), its much more like a misfire or lack of fuel (engine tries to fire and catch up with itself, but just cant). Also, the CEL was on when I bought the car, went away (thought maybe it was related to the sorely needed 60k), and now comes and goes as I drive every day, usually coming on right after the stuttering issue. I checked the codes, and got 172, 176 both banks reading lean), 542 and 543 (fuel pump secondary circuit malfunction). After doing a lot of searching, I cant seem to find anyone with the same problems as me. I have read that the fuel pump secondary circuit is nothing in most cases, but I have to wonder if its related to both banks being lean? I thought maybe it needed new 02 senors, but since both banks are lean, I have to wonder if the sensors are fine... I would appreciate any input. Thanks!
