1993 Sho
Nedmonds
Micigan
Just purchased my new SHO (1993 3.2) from another forum member here that i work with. It has an oil leak from the rear valve cover gasket, I got all my parts in now (150 dollars later :p) and cant wait to get this fixed as its a horrible leak. Before I jump in I need some advice on how to go about doing this. I have my intake manifold, valve cover, and spark plug tube gaskets all here and ready to go. Ive never changed any gaskets like this on a newer motor before and really dont want to mess up my new car. Any help/advice is GREATLY appreciated.
Also, every once in a while it doesnt want to start, almost like the fuel pump isnt sending anything to the engine, is this a common problem in cars like mine?
ohfosho
ontario SHOwner
ontario, canada
pull the codes after a good ride. has it stalled on you while driving? if so, you can bet that it is your CPS (crank position sensor), and or CID (cylinder id/cam sensor) research front and top '60K services' before you dig in...you might find more stuff that is a good idea to do while you are there.
1993MTXSHO
Its a Taurus...
Jersey
My 93 mtx does that. If this is what your tyalking about, When its cold or semi cold (not fully warmed up) and I stall it sometimes it doesnt start right back up. It takes a while to start and sometimes i pump the gas a few times when im cranking and that helps. Maybe you can try that I dont know if it will help you just dont flood the engine:thumb:
JoesSHO
Reality
Where in Michigan are you?
Hit up the SHO Phoenix Project website HERE and make a donation too... For info on the car.
