1991 Mocha sho - NY
Binghamton, new york
This is a clean and well taken care of 1991 Mocha Frost Taurus SHO . It came from colorado 3 years ago and now is in NY. It does NOT suffer from ny rot. It was stock when I bought it and within the last 5,000 miles Ive put on Shosource 12" rotors with dual piston calipers, russel stainless lines, and remanufactured from Shosource 94/95 knuckles up front. New stock rear rotors and calipers and I have russel stainless lines for the rears also but not installed. Hawk hps pads all around, Magnaflow Y-pipe, Moog inner/outer tie rods, and an alignment. I also have a set of new rod bearings, a spare intake (runners, tanks, butterflies), and extra SHO body cladding. The clutch was done by the previous owner and although I am not sure of the brand I do know it only has 15k on it. The mtx shifts good, I changed the fluid in it about 2,000 miles ago. Oil changed every 3,000. Never had a problem with this car . The only thing on this car that needs tending to, which I will be doing this winter is the current drivers door SHO cladding has a rust strip. The other bummer on my car is it has 160k on it. Every picture is recent and represents the cars current condition. Normal dings in the paint. Nothing major. Small dent on top of front drivers fender.
I want to sell it to a good home. If that means losing my ass bad Im ok with that. Make an offer, I wont be offended.
2dtyvyt
2w1xqnn
F56ihi
Ixav6s
23j5vzc
AREA 91
PA SHO SHOP
Area 91
Wow! This would be a great replacement for me. It is just like my first one that is near dead from rust. I am interested in the car. Can you send me some more pic's?
Banshee
New York
I've been to car shows with this car next to mine. He's a good dude and the car is as clean as it can be. Even though I'll be the only sho in the 607 if he sells it it really deserves a good home. It gets a lot of attention at our car shows. Glws Lincolnwelding.
AREA 91
PA SHO SHOP
Area 91
What is the build date?
Rod shifter?
Power bulge hood?
Power passenger seat?
Moon roof?
Rod shifter?
Power bulge hood?
Moon roof?
Build date Im not sure of. I will look into it after work. It does have a rod shifter, power buldge hood, and power passenger seat. And no moon roof. Also I should note that every thing works in the car, every seat function works (lumbar, bolsters, foward and back), ac blows cold, heat blows hot ect ect. The plastic trim around the drivers seat controls is cracked. And the it could use new rear struts because it does currently have sas.
Mikey
Dallas, Pa
Hey my coworker saw your car on craigslist. So I SHO'd him this post. You may have a serious buyer in Scranton PA. I added your brake and shifter upgrades make the car worth the price alone. Good Luck!
