13+ Interchangeable Brake Rotor Sizes?
BayAreaSHO
Bay Area, California
I have a 2011 SHO non-PP I was searching the forums and I came across a thread from a while ago and Im getting the vibe that the 13+ front rotors are able to fit on the earlier Gen 4s too. I was wondering if it was the same case for the rear brakes as well. I was going to get this kit here: https://www.stage3motorsports.com/K...O-Powerstop-Z23-Complete-Brake-Kit-352mm.html but I didnt want to order if the rear rotors wouldnt fit easily. Any help would be appreciated, as well as any other brake kit recommendations. Not set on these, just the ones that I see a lot of people running!
Rear brakes are unchanged AFAIK, and are used across all MYs and trim levels. But those with handson exp can confirm.
Airborne
+13 brakes will bolt right up, but you are going to have to bolt on +13 calipers in addition to the rotors, front and rear.
Did this on my wife's 2012 MKT and my 2012 MKS.
Pedal feels a lot better too, with the +13 brake booster and master cylinder.
And definitely the best bang for your buck for upgrading 2012 and earlier models
hosbaldosho
