13" cobra rotors from which year cobras?
adidas_kn
LOWSHO
Houston Texas
I have the 13" cobra brake upgrade on my 93' and the rotors rusted to **** from sitting for soo long. I don't really want to have to try cleaning the rust off of them. A guy up here has a brand new set of drilled slotted Mach1 Cobra Bullitt rotors from Napa for $100. I still need to find som matching 11.6" rotors from a 96-99 to finish the rear.
Later
"J"
SableSal
SHO-ABLE Owner
Fresno, Ca
94 and up is the correct years. You will have to drill out the bolt pattern. Don't worry, if the holes are a bit too large, it's all hubcentric anyhow ;) :thumb:
Sal
SableSal
SHO-ABLE Owner
Fresno, Ca
Oh also, I painted my rotors cause of the rust. A wire wheels and Engine Enamel Dupli-Color paint does wonders.
Plus it's way cheaper then $100... but then again depends on how rusted they are. I mean, I do live in Cali...lol
Sal
SableSal
SHO-ABLE Owner
Fresno, Ca
I've taken the car for a 500 mile run, and nother yet. I resurfaced the rotors after painting them. So the paint is not touching the brake lining what so ever. They are holding up perfectly fine so far...
Sal
ManySHOs
South Jersey
Later
"J"
Why not drive the car for a mile? That rust will disappear quickly as you use the brakes. I had 4 months of rust build up on my wilwood rotors while the car sat during the engine swap and build. It came off without a problem.
I also paint my rotor hats on my solid rotors. I use high temp paint and have never had a problem.
Ian
SeanMc
NoMoSHO
AAAWW YYEEEE 13s on da Siznable! Sal's brakes are one of the appeals of his car, you should see the rest of it in person.
SinisterSHO
Rust free
630, IL
Later
"J"
You got money just burnin away in your pockets, dont you?
dan.delargy
