David's93SHO
Hey guys, I will give you the low down, just bought this car, 93 SHO ATX, test drove the car and bought it, ran perfect, the ATX fluid is perfectaly red when I test drove it and now. It shifted fine and on the 2 ocasions that I brought it up to 65MPH(basically 1st to 2nd shift) at WOT it shifted nice and firm. Had to try it out with my friend. Other then that I never bagged on it, I only have had it for one day.
OK this is what happened, at a red light, looked to my left because I was making a right turn on red, just as I turned the wheels it made a bang and the whole car ****** from it, felt it through the seat, I was only doing 5MPH tops during the turn. I was just pulling into the parking lot that links me to my garage.
This is what I have found, jacked the car up, in park position the wheel cannot turn(checked one side at a time), in neutral, they turn nicely with no noise. I grabed the inner CV joint on the passenger side and it is loose where it goes into the transmission but the joint itself is fine. When I put it in drive or reverse, it shifts into gear perfect but it makes a loud noise like splines are slipping on spline, almost like I stripped the splines out. In reverse noticable louder(cant hear the engine run), so basically I shut it down from thier. Other then that the level is up and still nice and red and smells perfect, it honustly sounds to be related in the diff or the drive mechanism.
So this is my question to you guys, what options do I have to beef up the internals, I dont see a reason to replace clutch packs or anything because it shifted fine, but is thier anything for upgrades to beef up these things in the diff section of the ATX, I just wanna fix the broken part because other then this it runs fine.
Like I said, I just bought this car, my last car was a 94ProbeGT, I converted it from a ATX to a MTX, has anyone attempted this on here with an SHO????
Well, I thought I got a good deal on this car, runs perfect, all synthetic oil, new water pump and all, 105,000miles and I bought it for $3400 with new paint, day later......ATX breaks, dont blame the seller though, it was unforscene and he himself when we went for a test drive told me to punch it to test the car out so it was not like he was hiding anything. Thanx guys
