02 Sensor Question
svtman
Sherwood Park, Alberta
I was getting a code for front Oxygen sensor on my 95 SHO ATX. I pulled the sensor to run the test to confirm that it is not working correct. I could not find the part number 13223 or 15716 anywhere on this Bosch sensor - all I could find was "LSH 64" and a bunch of other numbers with many more digits (again, none of the above). Should ht sensor have the correct numbers right on them, or do I have some generic Bosch sensor on my car? It failed the test anyhow (would not drop to .1V in 4 seconds) so I will replace it. Just curious about this part on my car that seems to be fairly new.
Dave
The Bosch 15716 is the direct replacement for both of the 3.2L SHO's oxygen sensors.
BIGSHOMIKE
Orem, Utah
I just did my rear one, and if I recall the part number was on the box only, and there were some other numbers on the sensor itself. (it was a Bosch part) Same with my MAP/BAP sensor.
