Sold!
Jonny Cash
Good boy
Hollywood, FL
hmm.
-whats wrong with the way the clutch engages. Is it a hard pedal? Why two different clutch components?
-Also, hows the ride with cut springs, any clunks, noises etc.
-Does the AC work?
-Is the title clean?
And the rust situation. The brake knuckles/pinch bolt, subframe/bushings. Can you snap an underneath picture?
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
hmm.
-Does the AC work?
- The clutch engages at the very top of the pedal. Halfway travel on the pedal (top) is semi-soft, but the bottom half is almost like there's no pedal. I installed a CMS1 kit last year, and after 2,000 miles (if that) the disk failed. The PP was good, so I installed it with a Spec Stage 1 disk.
- Harsh. Between this week-end and next, I'll be installing the Koni/Intrax set-up.
- The AC I do not believe works. I think the compressor engaged (or didn't), I can't remember. It wasn't an issue for me (I rarely use AC), so I never tried to troubleshoot it. Your definately gonna need it down there.
- The title is clean!
- Every front suspension bolt (rear pinch bolts, endlinks, control arms included) has been turned/greased between this summer and last. In fact, when I went to replace the trans the first time, everything came off like butter including the exhaust manifold nuts. For a car thats been in the Northeast its whole life, it has very little rust.
I can't snap any shots right now because the car is in the body shop having the front bumper re-sprayed to match the rest of the car.
Mr95Gl
Mr Tire Iron
Brooklyn, N.Y.
BUMP! $2,000 . . . . . . please PM me for details. I'll get some updated shots of the interior.
warmonger
earth
2k as it sits,rims,clear corners? how bad are the seals and bushings? hc leaking or shot?
warmonger
earth
would you be willing to meet me half way if i payed extra? my zip is 12197
droptSHO
Wheaton, IL
Too bad you're not closer. Sooo clean and love that stance. We have the same suspension set up but mines too high :shrug:
sho2see
sho2see
Baltimore, MD
Well just to say I saw the car today and one word....WOW!!
Pictures dont do it justice, must go see for yourself how clean it is.
CAR IS VERY CLEAN
