Jet or ASP Underdrive pulley???
ALL4SHO2
SHO freak
Elmira NY
The title pretty much says it. There is only a $25 difference between the 2 with the Jet being the more expensive of the 2, but I am wondering if there are any advantage to either one. Such as longevity, quality or anything else?
Thanks
Eric
2 4shofast
Ogden Utah
If it were me I would go threw Doug at Ford Performance Specialist and get there kit. It is a one piece and not a bolt on pulley. That is my .02
hawkeye18
Sorta cares
Norfolk, VA
ASP had some problems with the crank pulley separating...violently... but that's pretty far in the past, I think they fixed the problem pretty quickly. Of course, if you're not getting the crank pulley, then you're set. Either is fine; I'd let your wallet decide.
ALL4SHO2
SHO freak
Elmira NY
what does their kit consist of compared to the others and $$ wise??
I've had the ASP crank pulley on for the last +6 years with no problem. Took it off once and the difference was really noticable.
