Key Fob
david3707
CT
Hi, i am wondering what i have to do to program a key fob for my 94?
boat
Likes blue ones
Tallahassee, FL
I am curious about this too. Mine didn't come with any key fobs. Wonder how hard it is to do?
Lupo
Huntington Beach, CA
Turn key to on position. In the trunk, go to you keyless module on the back leftside . You will find a 2 wire cable and connector coming from the module not connected to anything, usually snapped into place somewhere in left fender area.
Jump this connection. A penny works great. The car will then lock and unlock to tell you that it's ready to learn new fob. Then simply press the unlock on your fob, and the car will lock and unlock to signal it has learned the fob.
Do this with each fob you want to use (up to 4). Remove penny, and you are set.
swami
No. VA
i'd like to know where to get another used fob for my "94. my car only came with one. it only has two buttons to unlock and lock the doors and you can't start the car unless you first hit the unlock button or press the secret button on the bottom of the dash? the alarm also goes off when reattaching the battery or attempting to open a locked door with the outside handle. it also makes that alarm sound when you lock or unlock the door with the remote? TIA
