shomesomesho
G-force addict
I'm going to run this year without a rear sway bar.
After autocrossing this weekend in the cold bitter rain, I am reminded once again of the most common mode of wiping out in the SHO - no, it's not the front end pushing like a plow into cones, it's the rear end breaking loose culminating in a spin. A tailspin.
Even though she's running the smallest rear sway bar I could find in the (18 mm), the rear end is still too unstable for me to really be able to push this car as hard as I can. There's been this gnawing fear in the back of my mind that the rear will break loose, resulting in somewhat less aggressive driving and slower times. Slippery conditions seem to accentuate this weakness even more.
(For reference, last year's setup: coilovers 450/350, Koni's, 18 mm rear sb, no front sway bar; -2.6 deg & 3/16" toe-out in front; -2.25 deg & zero toe in the rear; 245 width tires)
Preliminary testing without the rear SB shows (subjectively) that the rear feels more stable, is less likely to spin, and actually feels faster through tight turns (since the rear tire aint scrubbing so much speed), without sacrificing too much of the car's ability to rotate.
So here's to planting the rear end, a more stable SHO, and faster autocross times. Bye bye rear sway bar, bye bye. :ciao:
Will let you guys know how it goes, but I'm feeling pretty optimistic about it already. :zoom:
