Friday January 4th
smokin joe
Milwaukee WI
Ahh i read logans post wrong now i know what he means, yeah I did, ass end came out around a turn hit a dry spot and shot me sideways into a nice 4ft high snow pile that turned out to be ice and bounced off that, Ended up with 2 flats and about 15-20 degrees of toe in on the front passenger tire. Got it home the next day and found out that i had bent the strut, almost broke the tie rod end link, so i replaced that, gave it an alignment in the garage, and then realized i bent a rim, put my spare slicer on it, so yeah fun stuff for me! Welcome to my life, the car had to F*#K me over one last time in 2007 Fix Or Repair Daily because Sh!t Happens Often
smokin joe
Milwaukee WI
well five winters in wisconsin without any accidents what so ever i guess i was due for something oh well it only cost me $26 for the tie rod end, and the aggravation of everything
joshy1410
Wisconsin
Hey, my car bit the dust lastnight, dang fuel System, so mine wont be running. Also, there is a chance i'll be in green bay this weekend. If my SHO was up I wouldnt even consider going.
Dan: My fuel Pressure Regulator was leaking. and it was too much of a pain to get it out so i sealed off where the leak was coming from with an expoxy. Drove it once it ran fine. I knoticed it was reall hard to start the next few times. Then while driving i would have zero power until my secondries kicked in. then it would take off liek a rocket. While it was in the driveway i took off hte vaccuume hose attached to the regulator. and it ran better, so when i was coming home lastnight from a party, it barley ran down the road, so i took off thast line and drove home, it made it, but it was smoking like no other. I knew it was the fuel that was causing the smkoe but the smoke was coming from the drivers side, not the passengers side. so that confused me. today im going to take off the epoxy as best i can. I have another regulator but i dont want to take the whloe intake off to do it, is there any other way. When it ran it sounded like it wasnt gettign any air.....? and while drivign she sound like a go cart with a fart can..... any help please??
ilikepoultry
6th motor SHO
Pewaukee, WI
The Water Street Brewery sounds like a good idea
maybe go cruising around the back roads by Pewaukee Lake or something
does that sound good to everyone?
Michelle
Wisconsin
Well make up your minds!
Since that will determine whether I go home or not. :)
Michelle
Wisconsin
Okay, BW3's on Highway 100. What time works best for everyone and who is all going?
Adam & Michelle
Dan?
Logan?
Frank?
Joe?
ilikepoultry
6th motor SHO
Pewaukee, WI
def. me.... i can go anytime... just give me like... 2 hours tops to get the brake fixed and a couple of test runs
and i'm starting at 10 AM... so anytime really
