1993MTXSHO
Its a Taurus...
So, why did this guy have your SHO in the fiirst place? Did you take your SHO to this "guy" simply to have the oil changed? Was this at a shop or quick-change type oil franchise? Regardless, I'd be calling the owner/manager to raise-****.
I just purchased this car, didnt bring it in to change oil, I never let people touch my cars
Smoking (due to water/antifreeze ingestition) is only going to be present if the head gasket is leaking into one or more cylinders - and then usually only after a period of time when the leak has become excessive. If the leak is between a water and oil passage, then you'll find water/antifreeze in the oil (usually the first indication) and oil in the radiator fluid (oil drawn through the gasket break during cool-down; requires a number of hot/cold cycles). And it is possible for the head gasket leak to result in both - leaking into one or more cylinders, as well as a between a water and oil passage.
You drove this 20 minutes? Did you not get an " [ OIL ] " light?
no, no lights or problems what so ever.
Did you get *any* oil while draining it? Did you actually measure how much fluid did come out? Why did you *not* turn the engine over with the DIS disconnected to flush any remaining antifreeze from the passages and bearings, as well as build oil pressure - before starting it? I don't understand the rush here, given the potential damage that may have occurred during the initial drive, and the uncertainty as to what is still inside the engine. And why "rev" it?
there was oil but it was pretty much mixed in with green, it was kinda oily antifreeze.
I didnt do that because I forgot to and the rush is its due for inspection this month and I need a car asap.And what do you mean by, " . . . . and this sucker still smokes like a chimney, . . . . "?
the oil smoke thats burning off the cat is crazy lol
Is the smoke coming off the rear converter? Are you sure it's due to an oil leak, and not a bad CV boot or water pump leak onto the y-pipe or converter?
yeah its a cam seal, that was checked by a mechanic when he owned it and by me when looked at the car at his house, its burning off the cat.
