strings1732
RMTE-TRBO-SHO
I've got it all figured out. I no longer bottom out because I raised everything as much as possible. The setup works and works wonderfully. I had a few bugs but all of them are worked out now. no more testing is needed to figure this stuff out. I have it done and it runs great(minus the blow off valve).
I'm using the tweecer to tune as was said and Jason(yamahasho) is helping me to tune it. I'm learning but it's taking some time.
all the pictures I have of the setup are on this website. Just search for my forum name and the words remote turbo.
At this point the long pipes are doing my charge cooling, but soon enough I'm going to add water injection.
I turn the key to the key on, engine off position to run the pump after the car sits. I plan to get a cheap ebay turbo timer to hook up to the oil pump so I don't have to sit there and wait.
With a larger maf, and the tweecer you can input the correct maf curves and then the computer will do the rest.
