jedhead
I would also check to make sure the 205/45-17 has the load capacity for the SHO. Load rating for the stock tires is 94 which translates to 1477lbs per tire.
Bob
Bob
crazy_canadian said:I'm running 235/55-R16 on my stock slicers. A very little rubbing on the wheel well. But 235s looks way too wide for these rims.
If you need serious traction, then you need serious competition tires such as Kumho Victoracer or Yokohama A032.jhollie said:Has anyone tries the Potenza's 225/50/16 extreme? I need some serious traction.
platoribs said:Gen 2
215/65/15
215/55/16
215/60/16 - Stock rims
225/50-16 (track only)
225/55/16 - Stock rims
225/50/17
235/45/17 (about 3mph off at 75)
245/45/17
235/40/18
How come the 225/50-16 are listed as track only??? Anyone know?
I have 17X8 OZ Racing Superleggra offset 35. I had to roll the rear fenders for the 235/45WR-17 to clear. I still have some rubbing when the suspension is compressed. I have SHO Shop Linear springs and Koni Shocks. The ride is firm.chknhwk said:Who all is running the 8" wide 17's? What size tires are you running and how does it ride? What offset is usual for the 8's? I'm thinking around +38mm?
This is a Gen I and will most likely have a stock suspension, I already have a race car and don't need another one...
