Use these directions at your own risk. I admit no liability whatsoever - this is simply a recounting of the procdure I used.
At the beginning of the summer, I upgraded my A/C. I waited till now to post the procedure to make sure it kept working. I'm not an A/C guy but I did a little research and it still blows cold so here goes...it's not that hard - just very time consuming.
Retrofit parts to convert to 134a:
Napa Rocks for A/C hoses...all parts pictured online.
$35 retrofit kit and 2 extra oil charge cans(they are small).
New, clean Mineral oil. This will be used to **** the new o-rings just like you would **** the seal on an engine oil filter.
accumulator(large diameter hose with big canister): napa part number TEM200680
Liquid line: (small diameter flexible hose - cause of "ford black death" if not replaced - google it - it's a real term) napa part number TEM200955
Discharge/suction line: (mates the other two hoses and hooks to compressor - has compressor manifold) napa part number TEM282810.
Compressor: must be compatible with 134a - any remanufacured 134a gen2SHO compressor will work - I stolt mine from a 95 automajic. Napa gets $385
+ a $60 core so I wont list the part number.
All these new hoses will have new o-rings...keep them safe or buy some extras - better yet...both. ebay is good for these. Search 134a o-ring
Procedure: dig in....get stuff out of the way.
Battery/tray
Alternator
Lower motor shock/bracket- attached to the front motor mount - I have reinforced motor mount so I discarded the shock/bracket - it's a noise/vibration/harshness thing. With the reinforced mount...it's rendered useless. Remove this for the A/C work as it's totally in the flippin way!
Upper motor shock and bracket - mine broke while removing - a better idea is to remove intake plenum crossover tube where the DIS ignition module is attached.
Power steering reservoir - don't disconnect hoses just move it out of the way. I shoestrung mine to the intake tubes.
Rear engine bay sight shield(vanity panel).
Coolant overflow bottle
That should provide you with enough room to get at all the A/C guts.
Procedure:
discharge the A/C system...If you are environmentally friendly, goto a service station and have them recover it. Other wise, empty it like a tire...dont touch the stream of freon - you wont like frostbite.
Start disconnecting stuff...I started at the firewall...This is where you say for the first time....not that hard?! that guys nuts. The little white plastic disconnect tools WILL work...use the right size and wiggle the shit out of the hose...because it's old it might be "frozen" together with a/c system sealant.
Once you have the hang of the disconnect tools...the rest of the disconnections will be just as hard...lol but its true.
Disconnect both fittings at firewall
Disconnect both fittings at front of engine bay...small one on top...larger one from underneath.
Disconnect the electrical fitting on the top of the big canister (this should be replaced too...it's the low pressure cut off for the compressor. 134a systems run at a different pressure - I reused mine...it's really a safety cut off so the compressor won't run while the system is empty.
Unbolt the A/C compressor manifold and remove all three hoses. The large diameter accumulator hose will be a little tough to thread out but with the right stuff out of the way..it is possible.
Unbolt the compressor and set aside.
Now all the old hoses and compressor are out and the only things that remain are the condenser and evaporator - everything else gets replaced.
Bolt up the new compressor but don't remove the shipping plugs if there are any...if using a salvage compressor, make sure to cover the holes with masking tape immediately upon removal from donor car - dont want to get ANY gunk in there. A quick check to see if the donor compressior is any good can be accomplished by seeing of there is any pressure in the donor system. depress the stator valve on the firewall of the donor car...if it hisses, the old donor car had at least SOME charge...indicating that there will be little if any contaminants in the compressor.
Carefully install the new o-rings on the new compressor manifold - scratched o-rings amount to leaks. **** the installed o-rings with a (clean)finger covered in mineral oil - just enough to moisten them. remove plugs or tape from compressor (clean surface of salvage compressors with alcohol or brake cleaner on a shop towel or scotch brite pad- get it good and clean) and bolt manifold to compressor - I made them almost as tight as I could with a 1/4" rachet and wrist torque(no pulling or pushing) - the bottom line is...don't crank so hard you break or strip things - there might be a torque spec...but I found none.
The other hoses should snap together quite easily.
Reassemble accessory train/button everything back up except for the low pressure cut off switch.
Charging the A/C system:
With the car shut off, charge the system with the 2 small cans of A/C oil charge - I think they have 2 ounces of oil each.
Start car and turn on max A/C - your compressor will not start because the cut off switch is disconnected. You have to jumper the switch to start the compressor. I jumpered the compressor 5 times for 5 seconds each - wild guess. I did this in order to circulate the oil - I don't even know if it's right but it felt like a good idea at the time - I doubt theres a guy on the assembly line at Ford that does this.
Plug in your low pressure cut off switch.
Charge the system with 1.5 large (15 ounce) cans of 134a retrofit charge - these also contain oil and system sealant and conditioner. Your compressor should automatically come on once there is sufficient charge. If not, disconnect the cut off switch and jumper it while you charge the system. The compressor must be on during charging. I think the capacity is between 25 and 30 ounces, but it should be on your emissions tag attached to the radiator plastic information thingy - I'm told by an A/C guy that you can't over charge with these small canisters but if the system calls for 30 ounces of r12 - use 25 ounces of 134a or until your vents blow cold enough.
I'm sure there are others that have slightly different procedures in mind but this seems to be working for me. I hope it helps you. It's been several months since I performed this procedure so I might have forgot the carrots but the meat and potatoes are all there. This is WAY more direction than I had so I'm sure you can do it if you DECIDE.
+ a $60 core so I wont list the part number.All these new hoses will have new o-rings...keep them safe or buy some extras - better yet...both. ebay is good for these. Search 134a o-ring
Battery/tray
Alternator
Procedure:
