Picked up a wrecked 97 for the motor - what else to keep?
Beartooth
Roberts, MT
Greetings, and my apologies for dropping in without being able to say if I'll stick around. I'm here because I've always loved the SHO engines - just too pretty to ignore - and always figured I couldn't pass up a SHO (car or just engine) if it fell into my hands at the right price. Well, this might be Copart getting me in trouble again, but one popped up for sale near me, and it's now mine.
54332186 Image 1
54332186 Image 3
Obviously the car is unrepairable, practically speaking. I have no idea of the mechanical condition since I didn't get a chance to inspect it, but I can't imagine it slipped a cam sprocket THEN got into the accident... I pick it up in a day or two, and I plan to pull the engine and transmission, plug everything up, and stash them until I have something to put them in. I've got a ton of ideas to swap it into something, but if nothing else, it wouldn't be hard to find a lessor 3rd-gen (or maybe 4th?) to turn into a SHO... That engine would look amazing under a translucent cover in an Fiero or something, but I'll have to give myself a deadline on the exotic swap ideas. I have the facilities to pull off a Frankenstein swap, but it's going to take a major commitment (Lord knows the forums are littered with projects that go nowere), so I'll just create another SHO if it sits too long.
Anyway, for now I need to strip everything worth saving and haul the rest off shortly. The list of "save" items (outside of the drivetrain) includes rims, rocker panels, front seats, and instrument cluster (I may use it if I swap to another chassis). What else is unique and worth saving though? Like I said, the bulk of it has to go, but I'm willing to hold onto some bigger pieces if they'd be useful to someone. Finally, I don't want to step on any toes posting parts for sale in the wrong section, so I'll pay up and create a thread in the classifieds section once I've got stuff pulled.
Qshiplvr
P Springs
You need to pull the ABS module, because that is a SHO ONLY piece, and YOU NEED IT TO MAKE YOUR AX4N shift correctly. Here's my post: https://shoforum.com/threads/gen3-s...-also-eatc-instrument-cluster-refurbs.147605/
The radio/integrated climate control unit in the dash has a habit of going bad. Might want to keep it as a backup if nothing else (EATC) as mentioned above. Agree with ABS module also. Computer.
Since the radio face is integrated with climate control...if you want the rest of the stereo system, the majority of it is in the trunk. amp/tuner if I remember correctly
Beartooth
Roberts, MT
Great tips, thanks guys! I would never have figured the ABS module would be unique to the car. I plan to pull everything that interfaces with the engine and/or transmission, within reason; obviously I want to hold onto everything it'll take to make it run again. It's kind of tempting to grab everything that could be used again (doors, windows, interior), but I might not have enough time and storage space. I can stash stuff in the trusses of my shop though, and toss it later - not that de-cluttering is a skill of mine... Anyway, I was going to get it today, but ran out of time trying to fix a bad circuit in the wiring to the trailer hookup, so I'm going for it tomorrow.
Qshiplvr
P Springs
I forgot something else...I noticed that one of the exhaust tips in the photo looks creased...not sure if repairable, but again, the exhaust tips are SHO ONLY so you should try to keep those as much as possible.
Qshiplvr
P Springs
If equipped w/ the upgraded sound system, your SHO should have a mid-rear deck subwoofer that is also SHO only, so when you pull the audio equipment from the trunk, also grab that sub hanging down from the center of the package tray
Qshiplvr
P Springs
Of course, you are most likely aware of this resource, but https://www.v8sho.com/SHO/96shohome.html is a GREAT library of reference stuff for Gen3 SHO!
E1
Crash Tested
Chicago area
Only '96's had the JBL system with the subwoofer.
'97's had the premium sound system minus the center speaker.
E1
Crash Tested
Chicago area
just throwing a stinkbomb in the room - how would one adapt the SHO ABS sensors to whatever car this enthusiast might wish to put them into?
The tone ring has a dedicated number of teeth on it, which means one has one choice for tone ring diameter.
Qshiplvr
P Springs
So taking this thought thread further...if the AX4N tranny is controlled by the SHO only ABS controller, would then that mean that only the V8 SHO engine and no auto? I think someone adapted a 5 spd manual from MX6/Probe to work w/ the Gen3, so maybe that route?
Beartooth
Roberts, MT
Hmmm, good to know about the tone rings. What the drivetrain ends up in, and whether the AX4N comes along (assuming it doesn't end up in another Taurus) is very much up in the air... I love the idea of putting it in something mid-engine with a stick shift, but whether I find a good candidate and am able to devote the effort required are open questions. Meanwhile, one priority is making sure I don't miss anything I need to make it function as it was delivered from Ford. There's always stand-alone EFI, if need be, but might as well keep the option of the factory setup if at all possible.
Anyway, it's in my yard now! Ironically (I think), it was hauled home by another '97 Ford - of a very different type, but also with a V8... of a very different type.
IMG 20260708 163626
IMG 20260708 205730
You can't see it, but one of the tail pipes is intact (on the side you're looking at), but the other is pretty badly mangled. One might be able to straighten it, but at best it'd only look good from a distance. Oh well. The tires on it are only a year old (2025 date code) - Yay! But they're Wal-Mart tires (Douglas brand) - boo!
IMG 20260708 210634
The interior is in really nice shape except for the airbag damage, obviously, and the driver's seat is bent back pretty badly from the accident. It might still be worth keeping the interior, but the biggest missing piece (a good driver's seat) is the one that's also hardest to find. I'll have to think about that one... It does have the Mach audio, but just plain old speakers in the back; I wouldn't have tossed the subwoofer, even if it didn't have much on aftermarket stuff. I'll probably keep the front speakers; not sure about the rears since they look like probably the same ones I pulled out of my truck (which I upgraded from, but I held onto for no good reason).
IMG 20260708 234237
Completely useless and probably worthless, but it was cool finding a Ford cell phone! I'm guessing they're not rare enough to be collectible, but I bet the take rate wasn't very high, even on top models like the SHO...
Unfortunately, I didn't have time to try and fire it up. I found the negative battery wire has been cut, and when I touched the ground wire to the negative terminal, the horn went off. I'll pull the fuse and reconnect everything tomorrow. I'm also guessing the fuel pump inertia switch is tripped and the cooling system is compromised, but if I can hear it run before I pull it out to ensure it's not hiding some major issues, that'll be a relief. Once that's confirmed, it'll be time to start hacking and yanking (with the appropriate care, of course). It's still a shame this car got wrecked. It wasn't pristine to start with, but it seems to have been well cared for - not badly faded or trashed.
Qshiplvr
P Springs
The front seats look like they're CLOTH???? That's pretty rare option, isn't it? I thought most all SHO's came with leather seats? Also, that Ford phone looks a lot like an Audiovox.
E1
Crash Tested
Chicago area
To my knowledge, 2 V8's were converted to stick shift.
Scott K. did one with a (I believe) Mondeo transmission.
Ryan P. did one with the earlier generation MTX from a V6 SHO.
Both have moved on to new owners.
venom
Rowboat Design
Toledo, OH
Howdy all Scott here .... I'd estimate 8 or 9 were converted to MTX. Im still planning to do another. I have the Getrag MMT-6 (6 speed MTX) from a Mondeo ST220 in the garage currently, and a 98 SHO with a gimpy ATX but Sadly i've had all of this for about 18 months now and haven't started...
Beartooth
Roberts, MT
We have a runner! All I had to do was re-connect the battery and reset the fuel pump inertia switch. It's making a whining noise that I think is the power steering pump, and it seems to have a slight misfire, but hopefully there's nothing significantly wrong with the engine. I'll probably do a compression test at some point and call it good if I don't see any weak cylinders. I do have a leakdown gauge too, but I'm not sure if that's worth much more than a compression test if the engine is cold. It definitely looks like there's no coolant, so I can't run it long enough to bring it up to temperature.
Yup, cloth interior. I dug into my old Standard Catalog of Ford, and if I'm reading it right, leather was optional on the upper trims, including the SHO. Even with that, it might have been a special order thing on the SHO: I know some configurations are very rare because Ford would send out cars like the SHO for dealer inventory pretty much loaded (probably most manufacturers did that with top trims and special editions). The phone definitely looks like the bag phones I remember a few people having when I was a kid. It does turn on, and if it's not too much of a pain, I'll probably see if I can hold onto it. Oh, and it's made in the US! When's the last time you saw that on a cell phone?
Good to know it's been done at least! I'm a big third-pedal guy, and having a five or six speed would be a big plus on a SHO, or whatever car I might swap it into. It's just too bad Ford gave up on sticks with the gen III - although they did come back to them now and then; my Dad has a '14 Fusion with a stick, I think they were gone again in '15. So there's a strong preference, and I hear the AX4N was only "not as bad" as its predecessor, so that's another vote for a stick. Another possibility is that it ends up turned 90 degrees. The two cars I have thoughts of for that are a Porsche 924 (I've got the turbo variant which I plan to keep original, but if I find another - preferably a 924S, but maybe a 944) or a Mercedes 190E. Digging around v8sho.com, it seems the engine is pretty light (360lb, maybe even a little lighter with a custom intake and some other weight cutting), so coupled with something like a T-5 transmission, you could keep the weight gain minimal or even cut some weight. Of course, I'm not looking for a barn burner here; I've already concluded that it's a case where you're happy with what it can give - hopefully a little more than stock with a better exhaust, but 250ish HP - or you pick a different engine. But that's all for later. For now I just need to get it torn down and haul off what's not worth keeping.
Brumfield780
