WTB: A Single 3.0L Timing Sprocket Bolt AND A Single Valve Spring Keeper
Deathacus
Pennsylvania
1994 SHO MTX. Need a single bolt for the camshaft timing sprocket, and need it quick.
Unless there is another more common car that uses this same one, cause there ain't any SHOs in the local yards.
Deathacus
Pennsylvania
Rounded trying to get off. Maybe over torqued from the factory? Had to weld a big nut over it since my vice grips and bolt extractor just...don't work.
Irish Pride
Irish Inside
MusicCityUSA
Are you talking about the crank shaft damper bolt? The 19mm one? If so message SHO Source. I picked up a few spares from Mike not to long ago for the same reason. If he doesnt have any more let me know.
-Chad
