With bc coilovers on my 2011 Taurus SHO non PP, what end links do I need to get when upgrading my rear sway bar to whiteline?
dallsbeep
Juneau, Alaska
Would like to get everything installed at once in a shop and not waiting on parts. Have ordered rear camber bolts just in case and looking to swap out rear links as well. I have heard i might want adjustable links but whiteline doesn't have any for sale that they want to recommend. What can I refresh with while in there that are large enough that they won't bind with the coilovers in the mix and make things as easy as possible for installers?
Kevin Curley
Tennessee
I used these on my 2013 and they worked just fine. The stock ones were causing the sway bar to rub on the lower control arms pretty bad. I had the Megan Racing coilovers but I assume dimensionally they should be similar.
dallsbeep
Juneau, Alaska
Was this on your front or rear sway bar because I'm looking for rear and that link says front.
I spoke with whiteline tech support and they recommended their KLC144 to use with the coilovers. They said it would cover a 3.5 inch drop to 4.5 raise so should work with the coilovers. I ordered a set and will see how it all shakes out.
Kevin Curley
Tennessee
It does say front, and I can't for the life of me remember where I saw it, but they were recommended from somewhere that they would fit the rear on the SHO's so I bought them and they fit fine. I ran them for the couple years I had the car with no issues. But I would certainly use whatever Whiteline recommends.
lingyuair
