Smoke out of Exhaust
wingingmean
New cumberland wv
I get smoke out of the exhaust here and there, So I have put a oil catch on, Changed the PCV valve, O2 Sensors and the Cat. I get a check engine light here and there for that.
The CE is on the front Bank. I'm thinking it could be the oil lines to and from the Turbo. Any help with this is greatly apprenticed.
Thanks
Texas Marauder
Lone Star State
So, 77k and you barely drive it. It had @60k when you got it(doesn't matter)? My front turbo oil seal start leaking @55k. I didn't know at the time that that was the problem. I figured that both turbos needed replacing. Had some smoke but, didn't use any oil between oil changes. I finally got around to replacing only the front turbo @89k. The rear is still OEM @116k.
wingingmean
New cumberland wv
Did yours smoke all the time. I've maybe put on 4k since ive owned it.
Did yours making a whining noise, or lost of power anything like that.
Texas Marauder
Lone Star State
Did not smoke all the time. Mostly on deceleration. No noise. Ran normal. As I said, I drove it for +40k like that.
76FoMoCo
Nampa, ID
wingingmean
New cumberland wv
Good info, if it is seriously think I will be pumped, I will get it ordered today thank you for the heads up
wingingmean
New cumberland wv
If you still have the old PCV valve you can save yourself a few dollars. Just gut the old PCV valve and install that on the front valve cover. It is virtually identical to the green fitting. This was a fix for cars that smoked after after idling for a while, like police cars. Hopefully, it will fix your problem. Otherwise I think you are looking at a turbo replacement.
Fingers crossed I dont need turbos, its on the horizon for down the road. Just not right now.
wingingmean
New cumberland wv
I'll also note that when my smoking problem started I replaced the PCV fitting with the green fitting in hopes that that was the problem. Of course, it wasn't the problem.
Fingers crossed mine was good today I replaced it with the old valve, I got on it pretty heavy. No smoke so far. I check the hose that goes from it to the intake no oil in it. I clean it when I changed them out last night. She had some oil in her
Texas Marauder
Lone Star State
I hope you mean that you removed the valve, spring and retainer from the old PCV valve and just used the external housing.
A few months ago I had an encounter with a fellow SHO owner. A stranger to me. He had some sort of problem with his dual catch can system. He had just replaced the PCV valve, on the front valve cover. I informed him that the PCV valve was on the rear cover and he now had two PCV valves which actually disabled the PCV system. I removed the guts of the new front PCV valve and sent him on his way.
wingingmean
New cumberland wv
Yes sir I did, I might not be the brightest crayon in the box, but I do have common sense lol.
tinkerkathleen
