What oil do you use?
gamefanatic
Barstow, CA
Never have used Royal Purple, I don't believe it's readily available in my area. Typically use Mobil1 5w30 High Mileage Full Synthetic and change every 3K miles along with the M1-209 filter. Got'em setup for delivery through Amazon.
I also use M1 5W30 High Mileage oil. My typical day is 50+ miles, and I have done enough used oil analyses to know that I can do 10k oil change intervals, which I do. However, anyone with a turbo engine should change at least every 5k miles. There are plenty of other very good synthetic oils out there. In fact, I have had very good experience & results with the Walmart full synthetic, but I use M1 instead because the Walmart stuff is a little thicker, particularly when it is cold, and it occasionally gets cold enough around here this time of the year that I can really tell the difference at startup.
I wish the TGDI engine oil was as simple as this. Lol.
Irish Pride
Irish Inside
MusicCityUSA
If you are using Mobil 1 and changing it every 3000 miles then you are just throwing you money out the window. The only advantage I can see to using full synthetic oil is for the longer mileage intervals it allows.
I use Motorcraft 10/30 or 10/40. Depends on the car I'm servicing. All my cars oil changes are set up with 5k mileage on the odometer. 30k, 35k, 40k, etc....
-Chad
gamefanatic
Barstow, CA
-Chad
Fair enough, just been going by the Ford recommendations. I realize the Mobile1 states 10-15K on the bottle, but I don't mind being a bit cautious. This may also explain why my engines internally are acknowledges as being so clean!
Sparhawk
Knight X-treme
Santa Clarita, CA
I use Mobil 1 5W-30 High Mileage Extended Protection with an oversized Mobil 1 M1-301A oil filter (Motorcraft FL-1A equivalent) that lets me change my oil and filter once a year. Usually that averages to around 7k-8k miles driven between each oil change. I've switched to this combination and interval about 50k miles ago and have not had any mechanical or oil burning issues since going this route.
Hollon71
Harlingen, TX
Well, I have used the Mobil 1 oil in the SHO. I don't have it back in my hands, YET. There are sooooo many things that the previous owner DIDN't DO to this SHO!!! One o2 sensor was missing. The fluids that were drained were the wrong colors, if you know what I mean. Replacing ALL 3 Motor Mounts. Replacing the gas cap and battery. He also advised me that the SHO is already running MUCH BETTER than how it was when I picked it up and drove it 300 miles.
E1
Crash Tested
Chicago area
Is it WELDED ! ? ! ? !? ?????
If Not.......
(Nothing else matters)
I saw your pix from bringing home the car.
That Black Top degasser tank will let you down. They ALL fail. You get a crack in the tank on the under side and it only leaks at highway speeds. You won't know WHERE the coolant went, but it always seems to disappear. Dorman 24 v DOHC Taurus tank for same year is a direct replacement.
gamefanatic
Barstow, CA
If Not.......
Most times it rips along the seams, but I have had the sensor fail on my last 3 tanks helping to keep them fresh. Good thing they are still available with lifetime warranties! :cool:
Hollon71
Harlingen, TX
Lifetime Warranties are LIMITED Lifetime Warranty. I advise all of my clients at the O'Reilly Store I work at.
E1
Crash Tested
Chicago area
The early cars came with a "Premium Fuel" admonishment on the dashboard.
Later years dropped this requirement.
Many discussions on V8SHO.com and it was determined that premium fuel was not worth the extra expense.
Car runs the same on 87 octane.
Hollon71
Harlingen, TX
Thank you. When I picked it up, I used premium for the 300+ mile road trip since I have no idea what the previous owner used.
imho, there is an advantage to using the premium fuel because the best fuel has more injector cleaner, which in my experience, allows one to drive the car without having to do periodic injector cleanout procedure. When you factor in that cost every few years, the costs balance out.
Hollon71
Harlingen, TX
I still use the Royal Purple FIC once in a while on my vehicles. Since I got the SHO last week, I have the oil and transmission fluids all changed. The transmission fluid looked bad. I'm not sure if the previous owner ever did it.
