Hey guys,
2015 67k non PP. Just got back from a roughly 45 minute drive, did a few pulls of course but nothing too crazy. When i was nearing home i noticed an odd noise, a repeating sound that seems like either air being sucked in or blown out, on and off maybe twice a second? kind of hard to explain, almost like blowing a raspberry but slower and deeper. the tachometer was also fluttering maybe 50 RPM either direction but no major hesitation or shudder in the car itself. basic research on the forum tells me the TC is a common issue with low RPM shuddering and hesitation. The car still drives fine and has plenty of power it only was noticeable right when it starts to build boost and then the noise goes away. Only modifications currently is an Airraid intake and the VTA mod with chair leg caps...classy.
I did do a quick check with a flashlight and all the airflow related components i could see with a flashlight from the engine bay looked OK. Tommorow i will try and go over everything more thoroughly. This car is still under the 90 day purchase warranty and honestly im going to end up taking it to the dealer and have them fix it but for my own edification I still want to know what went wrong, why it went wrong and how to fix it. I'm a mechanical guy by trade but ill be the first to admit i know almost nothing about cars, but i plan to keep this thing for a long time so its in my best interest to try and learn as much as i can. thanks
. reconnected that and the wastegate linkage and the problems went away. no more stuttering, no more overboost. car pulls as good as ever. i still think i have a few minor boost leaks and the car still seems to be making a lot of pressure on the boosted side, perhaps due to the intake and downpipes on a stock tune. BOVs blow off hard if you even tap the throttle and kind of whistle even when your cruising...i did just install the Torque Solutions BOV adapters maybe they are affecting it idk. but the worst of my issues seem to be gone for the time being
