I was looking at gearhead and decided to go with that, thanks for the help everyone!Get an SCT device and use AJP, gearhead, unleashed for your tuning.
3 BAR MAP - Ford performance plugs - replace the air filter - keep the stock box with a K&N filter - 170 degree T-Stat - next steps might be high flow cats - removing the restrictions like stock resonator. I am sure I might be missing items. Look over peoples signatures to help.Is there anything I should do to the car before I get the tune?
100% agree. 3 bar MAP, cooler plugs, air filter, 170 degree thermostat, and a tune. You'll get a nice upgrade per dollars spent and it's safe/dependable to drive daily. I've had it for about 5 years now. Might also want to get a catch can, but that's more of a maintenance thing (stops oil blow back) rather than performance upgrade.3 BAR MAP - Ford performance plugs - replace the air filter - keep the stock box with a K&N filter - 170 degree T-Stat - next steps might be high flow cats - removing the restrictions like stock resonator. I am sure I might be missing items. Look over peoples signatures to help.
UPR catch can! They have 15-19 too: https://www.uprproducts.com/10-14-s...ost-dual-valve-oil-catch-can-css-plug-n-play/100% agree. 3 bar MAP, cooler plugs, air filter, 170 degree thermostat, and a tune. You'll get a nice upgrade per dollars spent and it's safe/dependable to drive daily. I've had it for about 5 years now. Might also want to get a catch can, but that's more of a maintenance thing (stops oil blow back) rather than performance upgrade.
Sent from my Pixel 7 Pro using Tapatalk
Crapola - I didn't see you in CA @studio460 will wake up and await you with what can be done.Is there anything I should do to the car before I get the tune?
