outside door trim
Morphy
Fayetteville, N.C.
On my 2015 SHO, the black plastic upper passenger outside door trim has come partially loose. Proper removal and repair? Looks like it is held in place with just double-sided adhesive tape. Has anyone ever dealt with the same issue? Suggestions and solutions would be appreciated.
Ta2dResqr
Central Ohio
I used 3M VHB and pulled back just far enough i could put the tape where I needed then pushed it all back together.
Morphy
Fayetteville, N.C.
Thanks for your input. That is what I was planning of doing. I did not want to pull the trim out more than it already is, to get a better look for any clips, and or attachment points. From what can see, the trim is only held in place by a strip of two-sided adhesive tape.
Ta2dResqr
Central Ohio
I didn't pull it out very much at all. Used a putty knife to get in there. Wasn't even pulled back far enough for my fingers to fit.
DouglasB_SHO
Former owner 2011 SHO
Sagamore Beach, MA
I had to remount my driver's side. I used 3M weather strip adhesive (aka, "yellow death").
Morphy
Fayetteville, N.C.
Did you have the trim piece completely off the car when you remounted it? If so, were there any clips and or specific attachment points visible during your repair? Mine is still on the car, just partially loose at the top left corner. I don't want to damage the trim by attempting to take it completely off to clean the surfaces before applying the adhesive. Right now there is just enough space to place a strip of adhesive tape at the top, half the way down the loose side, and maybe center mass.
DouglasB_SHO
Sagamore Beach, MA
I don't recall any clips. ... I'll check the service manual ... it describes the panels as "applique" and none show any fasteners. See items 3 and 4 in the image below.
1652904242356
Morphy
Fayetteville, N.C.
Thanks for your timely input. Looking at the diagram I don't see any fastening hardware. I believe all Ford did was use two-sided adhesive tape to attach these trim pieces. Thanks again.
