Side View Mirror Paint
Old Stang
Woodstock, GA
Hello All,
Looking for suggestions on paint to refresh the side view mirrors on my 94 ATX; the driver's side is the worst (see pic), but going to do both sides.
20201012 113608
Possibly someone like Eastwood or similar has a product to do just this?
Anyone had good results with a commercially available product?
Thanks in advance. :)
NoSlo
SHO Owner
Portland, OR
I just used glossy rattle can paint, probably Rustoleum Pro. Prep by sanding down all the rock chips (might be easier to sand on-car), remove mirror assembly and remove the innards. Hang with wire from bottom screw holes. Spray multiple layers so you can color sand. Buff and wax after a month. Shiny.
Lpj0jqu
PkixrrX
(also black vinyl tape on painted pillars and chrome trim)
SHOCH
Tommy Boy
near SHOcago
I used the same 3” pad on a drill I use for fixing fogged headlights. Mother’s Aluminum and Mag wheel Polish does pretty good.
Blk89
GA
I hear a lot about color sanding, what is it and how?
thegreatbriguy
Carlisle
Lpj0jqu
PkixrrX
wow, that looks good!
NoSlo
SHO Owner
Portland, OR
Even if you sand between coats of paint, new paint will always have some degree of orange peel and waviness to it, and fast-drying spray may have that overspray speckled look. You sand out the high spots with a block and high-grit finishing paper (2000 thru 3000), and then buff out the sanding scratches by machine for a mirror finish.
(White single stage (no clearcoat) oxford white is also receptive to this treatment...)
