Floooo-eedz
High on Ethanol
Just Ain't Care
USA
Let's get real low together, and go UNDER THE SEA!View attachment 14991
Noone has helped the guy asking about checking out a rear-end.
I thinks some other guy didn't know when to stop jacking or how high is too high.
Let's make sure we answer the important questions here.
SHO_Off420
US
I asked you and you never responded
Which cover are you talking about removing the ine on the diff?
High on Ethanol
Just Ain't Care
USA
The rear cover. I actually already changed the fluids. Im giving it a 10k mile test run. So far mpg increased by 0.8 and seems smoother on take off and downshifting.
SHO_Off420
US
In order to get it out you gotta cut of that useless exhaust hangar or go up over the top of the sway bar and out the back, which make it a massive pain to put back in with RTV on it so i recommend you cut the hangar off
Why would he cut the useless exhaust hanger off?
High on Ethanol
Just Ain't Care
USA
He said hes trying to get the diff cover out, that makes it way easier
The truck diff doesn't have anything in the way. I was just trying to drain it without removing it.
In the future there could be a better way.
SHO_Off420
US
He already replaced the fluid. Pretty sure cover was easy to remove, if he even removed the cover.
I believe he stated that he was unable to get the cover out to take a look at it, sounds like he cracked it to drain it and was asking how to get the cover out
SHO_Off420
US
Your talking about your ****** truck? I thought you were doing your wife's taurus lol
