Do you have a drain plug installed? If not, you may have sucked out the old fluid. In that case, you'll never get it all out and of course there is about 2-4oz of old fluid and wear sediment in the sump. I extracted mine and got about 10-12oz. I drained it when I drilled my drain plug and got about 16oz. Filled with about 18oz vs 12oz the time I just extracted it out.Yeah, is this the best fluid for the RDU? It's in the PTU as well. I'll have those test results probably by Monday
No drain plug, just extracting so it makes perfect sense what you said about old fluid and wear sediment. I'll know what those results are Monday. I've changed out the PTU fluid 4 times total since owning it for 22k miles. I should probably add a drain plug.Do you have a drain plug installed? If not, you may have sucked out the old fluid. In that case, you'll never get it all out and of course there is about 2-4oz of old fluid and wear sediment in the sump. I extracted mine and got about 10-12oz. I drained it when I drilled my drain plug and got about 16oz. Filled with about 18oz vs 12oz the time I just extracted it out.
It is a bit sketchy, don't want any shards or shavings from drilling getting stuck inside. I guess that would be more of a concern if it was bone dry at the time of drilling. Even extracting it, leaves about 6-8 ounces inside. Nothing should get stuck in there as the last of the fluid will be released once the hole is finished.I’ve been considering adding a drain plug in my PTU. Scary though, there doesn’t seem to be a ton of clearance between the case and the business. Also, I have no idea where the best place to put it would be.
Are the readings in PPM? (Parts per million)This low mileage sample (about 2k miles) was taken in October 2019 before my last track outing of the season. It was taken during another fluid exchange.
Although it is a low mileage sample, I would call it "Severe Duty". I'll use this as a baseline for further testing.View attachment 11696
Does anyone know the part # for the drain plug?
Perfect!I used this one.
1/8"-27 NPT Industrial Magnetic... https://www.amazon.com/dp/B002A378M8?ref=ppx_pop_mob_ap_share
Also with this tap.
GlowShift 1/8-27 NPT Drill & Tap... https://www.amazon.com/dp/B00CA91AIK?ref=ppx_pop_mob_ap_share
Thank you! Ordering now!I used this one.
Also with this tap.
