Fuel additives
Deezuz
Indiana
In the diesel world fuel additives are everything.
For lubrication purposes, what is everybody using?
b4black
IL
Don't need fuel lubrication in a gasser. They won't benefit from it.
(E30 certainly wouldn't help that.)
Knight
Bottle of Techron or Liqui Moly Jectron in the tank every 5K miles with an oil change. Wouldn't say it's critical but a minor, yet helpful preventive measure.
yaycandy
Aerospace Engineer
Hanover, PA
Techron has been used alot in the f150 ecoboost world. I use it alot, not sure what it has helped but i use it anyway. Best additive is to run at least 1 watermeth jet before throttle plate to help clean the intake valves. Only effective “additive” i can think of. It performs and cleans.
Johnbigdog
michigain
ford makes a fuel system cleaner that you can add to the tank. Available on the amazons cheaper than the dealerships.
Techtron is also a good alternative.
LilCop2002
In the South.
With the question being asked I have a similar thought... since my SHO can go 4weeks at a time without being driven should I consider using a fuel treatment such as a Sta-bil or would the Techron work well?
Johnbigdog
michigain
I dont think techtron is a fuel stabilizer? You'll have to look into that.
Stabilizer (stability or similsr) wont hurt anything.
yaycandy
Aerospace Engineer
Hanover, PA
Ive been fine, just use refinery fuels and techron at least at every oil change and crc intake valve cleaner. My sho is better in my garage just to look at. Driving cars really beat them up.
LilCop2002
In the South.
Now I think about it, I didn't really think the Techron as a fuel stabilizer but have no clue why I stuck them in the same group.
I may start with the Techron and if it starts sitting more than a week at a time I will hit it with a stabilizer.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
unless you run ethanol blends and it sits more than a month I wouldn't worry about it.
shobroooo
