Shhoebow
Yesterday my sho all the sudden lost all power I had just under a 1/4 tank of gas and could not even pass a minivan that was cutting me off..
I noticed that my oar was +96 and was knocking horribly at about +7.25
The few days prior my kr and oar has been around -50 to -96 on the same gas...
I Then I restarted and the car was fine I'm running (AO gearhead tune,gearhead intercooler Catless thunderstorm DPS and MagnaFlow catback) and all the little stuff...
It's been 3,000 mi since I reloaded my tune. I've done data logs in the past five of them. I left Matt from gearhead for now because I only get a few sentences out of them when he reads my logs, I don't matt at all because I know I'll just get it quick answer that doesn't have much information behind it
I do add 1 gallon of e85 with 93 oct. every other tank of gas I was told that I could do up to 2 gallons If I wanted to but I don't adjust do it to keep my KR good and OAR above -50
My question is has anyone experienced this and does anyone know what the rear fuel pressure should sit at mine currently at peaks at around 16.
And what else should I look at to see if I have enough fuel coming in I have a livewire device and I run data logs and look at them all the time but I have nothing to compare it to. Thank you in advance for reading this book.
Sent from my Pixel 3 using Tapatalk
