Low Mileage Black 1989 SHO in SE Michigan
Status
Not open for further replies.
apowers
Michigan
Purchased back in 2015 largely for nostalgic reasons and almost immediately started obsessing over ensuring all maintenance was up-to-date (see below). Car shows just under 80K on the odometer which I believe to be correct based on the Carfax from when I purchased it. Further evidence of this is the exceptionally minimal amount of rust on the exterior and underneath. I’m asking $3,500 and will include the original and extra parts I have for that price. Pictures can be found at https://photos.app.goo.gl/AtJq7DmwFdsgheKB9.
Since I purchased the car/within the last few hundred miles, the following has been done:
  • Full 60K with new belts, crank sensor, and cam sensor
  • New ignition coil and wires
  • New water pump, thermostat, all-aluminum radiator, and hoses with coolant system thoroughly flushed
  • New cable shifter ends and fresh transmission fluid (added pipe plug per instructions on the forum)
  • New O2 sensors, exhaust 2-to-1 gasket, springs, and bolts
  • Fuel tank dropped, rust cleaned off, and painted
  • New fuel pump, vapor one-way valve grommet, and filter
  • Front spindles from a ’94 with new hubs/bearings running calipers off a Mark VIII (i.e., 96+ upgrade)
  • Brake calipers rebuilt and new pads, rotors, and rubber hoses all around plus new hard brake lines from proportioning valve to rear hoses
  • New halfshafts (including trans seals), lower control arms, inner & outer tie rods, front and rear stabilizer links, suspension bushings, and Monroe Quick-Struts including alignment
  • Replaced passenger front door wiring harness (original had been cut at entry to vehicle)
  • Seats replaced with ones from a later model (Gen 2?) which are 9.5/10 and carpet cleaned
  • New 225/50R17 Michelin Pilot Sport AS/3 tires (on Borbet wheels)
  • New Kenwood media receiver (stereo) and Infinity speakers all around including 10" sub w/amp in trunk
  • Cleaned and re-oiled K&N air filter
  • New hood support struts
There are a few remaining issues:
  • Exhaust is leaking with large hole in driver side muffler, but isn't all that noisy
  • Engine mount(s) may need to be replaced (some polishing of intake manifold)
  • A/C is inoperable
  • Power door locks are inoperable (despite changing out door wiring harness)
  • Doors are not original to car and cards were previously modified
  • No antenna (but older satellite antenna box in dash)
  • Hood is missing two of the four bolts holding it to hinges
  • Remaining underhood rubber hoses (to vacuum reservoir and power steering) should be replaced
  • Rear bumper has a small crack
  • Paint shows its age with a few touch-ups needed (but has been clay-barred, polished, and waxed so it looks decent from 10 feet)
Other bits that will come with the car are: Ford shop manuals, various maintenance records, and some spare/takeoff parts including original spindles, brake calipers, and grille; door cards; some interior trim; and weatherstripping.
Shaggy
Administrator
Updated...
apowers
Michigan
@Irish Pride I didn't intentionally ignore your question, just using outdated info to try to get this post up (thanks @Shaggy ). I'd prefer not to start piecemealing things out (yet), especially when it involves disassembly of bits already attached to the car.
apowers
Michigan
I realized I was underselling the fact that this car has almost zero rust and I've been driving it a little which has led me to fix a few of the minor items on the negatives list (and remember other things I've done or should still be done). Original post is updated and a few pictures added to the link
apowers
Michigan
I was thinking about keeping this car, but with how much driving I now need to do (working from home), it just doesn't make sense. Details updated since I took care of a few things and price dropped.
apowers
Michigan
I updated the photo link with some new shots of the interior with all the stereo components in place.
apowers
Michigan
Totally agree. The '90 I had and other later examples I'd seen made me think all came with power everything, automatic climate control, and fancy stereos. Then there's this '89 with manual climate, a normal whip antenna, and seemingly very minimal radio based on the wiring I found inside the dash. I was also baffled for a bit trying to pull codes with the check engine light until I discovered it wasn't in the dash cluster and had been previously unplugged. :bonk:
apowers
Michigan
Car fired right up today after sitting since about November. Lots of $$$ in new parts so it should provide worry free enjoyment to its next owner for a long time to come.
glockcoma
Whereabouts exactly in Southeast Michigan? I’m in Northeast Ohio Cleveland area and I’ve been mulling over the idea about getting another gen 1.
I miss my 90 RIP
apowers
Michigan
I'm in Canton, so about an hour north of Toledo. I-275 is maybe a mile from my house.
Status
