Hub Size
Carl's SHO
Northeastern IL
Hello,
Will someone please confirm hub size is 63.4mm or 70.5mm? It looks like all 2010+ are 63.4mm but I can't find a 100% definitive answer. I assume the factory flower wheels have the same 63.4mm center bore.
2015 non-pp
Thank you
Carl's SHO
Northeastern IL
Hello,
2015 non-pp
Thank you
I guess I'm specifically looking for the hub diameter of the vehicle to know what size hub bore to get on spacers.
Kevlar07
100% 63.4mm just put bolt on hubcentric 20mm spacers front and rear on my 15 non pp. I did have to cut my studs back to clear the wheels sits square with the top of the fender.
glockcoma
Not to hijack the thread but any pics?
Kevlar07
Here you go
OmaHahn
Omaha
Please elaborate on cutting your studs back...
Kevlar07
The factory studs were too long when I bolted the spacers on and hit the wheel so I cut approximately 13mm off the studs 7mm of that was untreated so no big deal. I used a cut off wheel and went really slow spraying the stud with water so I wouldn't over heat and weaken the studs.
