SHO Gen 4/5 Puddle Lamps
StealBlueSho
NA
***UPDATE***: ICBM emailed me. They ordered 50 sets initially and those are just about gone. They will need to order more from their supplier once the first 50 are gone. This will add some delay to the process if you are order 51 and beyond. Just a heads up.
RAYJAY
WHO ME ?
UNION DALE PA
glad I'm number 37 ............
StealBlueSho
NA
Only 1 left for this order cycle!!!
StealBlueSho
NA
Ok... ICBM said they are going to request another batch from their supplier... unfortunately I do not have a time frame....
If I hear anything from them I will post it. Otherwise, if you did not get a set, keep an eye on the website..
Thanks everyone for making this successful!!
Pvster
I don't have a SHO yet. But when I get one, this is near the top of my list! Very cool and thank you for making this happen. This will make the SHO really pop as a luxury vehicle like it should.
gimpy
Pennsylvania
I'm fairly sure a second batch will go equally as fast.
There are a lot of SHO owners out there. Honestly, I didn't expect the first 50 to last that long and was worried I missed them when I checked the link today.
StealBlueSho
NA
9e79418c85d4d845e64384adcbb60c393671d3055a6ac8f43f94a6431288854c134f21a5eacadd6751da3fd0b7d65c1093bff699554bb2cfe85d5e59b31c5e2d
Not too shabby...
The adjustment bolt snapped on the passenger side... I will be notifying them.
6500rpm
Is there an "as built" code you can tweek on the 13+ that will allow you to change the amount of On time? I've always thought they turn off too soon, if you're going to have display lighting it would be nice to go the extra mile and set the On time to whatever you want.
gimpy
Pennsylvania
Mine came today as well.
Never tinkered with the puddle lights before. Any tips on removal before my clip breaking streak increases?
StealBlueSho
NA
So I broke both my clips on the stockers....
Follow the directions in the box.. loosing the one the side, then the other side, and the stockers should fall out.
bpd1151
Lurking Around
SHOcago 'Burbs
Really not much to it.
Tilt your mirror up as much as possible, take a flat head screw driver, push on the tab that holds the assembly in, then it pops/drops right out of the mirror assembly itself.
Unplug the wires, and plug new one in, push it up into the hole and done.
The only caveat being you may want to hold it in place (loose) to see where the logo projects onto the ground.
Use a Philip's screwdriver to adjust the logo left, or right (as needed) prior to shoving back up into the hole.
Done.
StealBlueSho
NA
BPD1151 is multitasking here... what you don’t know is he is pole dancing while texting out instructions... I’m impressed...
bpd1151
Lurking Around
SHOcago 'Burbs
This is VERY TRUE!!!!
